I have been playing all my DVD Divx Rips on PowerDVD Xp and I was wondering if there was a way to get it to go Widescreen on full screen. Make Sense?
When I have it in a window it does not have the black bars on the top or the bottom of the window. So when I hit Full screen it literally goes full screen and stretches everything out. Anyway to fix this?
-Spyder
Hi Spyder,
Makes perfect sense! Using PowerDVD 3, I was able to play AVI's in widescreen format, then for no reason I can think of, it wouldn't. I re-installed and made no difference. Tried keep aspect ratio and nothing. Sent my problem to CyberLink and the response was "Power DVD does not keep aspect ratio on .AVI's" But I swear that I was able to before. I know this doesn't solve your problem/question but you are not alone.
Good Luck! -
Originally Posted by Spyder
Is keep aspect ratio checked? It could also be a codec you may have recently installed. some support widescreen others don't -
When playing a AVI file there is no Option for "Keep Aspect Ratio". Also if I play the file in lets say Winamp 3 it makes it widescreen in full screen. The problem with winamp 3 is that the picture can not keep up with the sound and its poor quality. PowerDVD plays it flawlessly exept for the widescreen.
-Spyder
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
Widescreen aspect problem converting avi to dvd
By spiritgumm in forum Video ConversionReplies: 8Last Post: 10th Apr 2010, 13:14 -
Convert avi to 16:9 widescreen
By sknoxxx in forum MacReplies: 4Last Post: 28th Aug 2009, 20:50 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 01:49 -
AVI widescreen fix?
By robburne in forum Video ConversionReplies: 5Last Post: 23rd May 2008, 13:29
