If I install 3.11 then I install 4.12, when I goto add/remove programs only the 4.12 is listed.
Then If I install 5.02, when I goto add/remove 4.12 is gone and only 5.02 is listed.
Am I missing something here?
Do I need to be installing the older codecs or will 5.02 playback everything..
I just want the right combo to playback (and convert to (S)VCD) every type of divx files.
No thanks to NIMO-- Thats what started this mess for me!!
I installed that and my videos played upside down..
So i Uninstalled it and it removed all my codecs, now Im trying to get back to normal... -
To see if all three codecs are installed correctly just open any AVI file in Virtual Dub, go to Video->Compression and you will see the list of all the codecs currently installed which is more precise than the list in ADD/REMOVE PROGRAMS window.
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 09:44 -
Having issues with dvd ripping and codecs - cant tell whats installed
By alex.ap.pacman in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2011, 00:40 -
Windows 7 how to list installed codecs
By felix in forum Newbie / General discussionsReplies: 2Last Post: 21st Dec 2009, 07:33 -
Two sets of codecs installed - is that bad?
By lilblu in forum Newbie / General discussionsReplies: 5Last Post: 19th Mar 2009, 07:13 -
Application to View Codecs that are Installed on Your System
By JBredensteiner in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 00:58
