Can someone please tell me why no matter what the bitrate is, the filesize is always the same?
I'm using tmpgenc to encode a 2min clip into a mpeg1 file at various bitrates (200,500, 1150) but the filesize is always the same!
if you change the bitrate you also need to change it to Video CD(non-standard) on the last tab under settings. this will fix that file size problem; although i dont understand why you would lower it that far, quality will really suffer.
Question about FPS/bitrate<->filesize relationship in containers.
By Gew in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2010, 06:19 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 11:01 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 11:34 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 19:22
