1.)can i put a 82minute and 30sec movie on an 80 min cd???
2.)how can i tell if my VCDs are vcd1 or vcd2 ???
3.)what do menus do for you?? like i saw somewhere "adding menus" ???
thanks,
maiof
1. only when you overburn
2. usually authoring tools create only VCD2.0. The only tools I know, that allows VCD1.x, is VCDImager.
3. Have you ever seen a DVD menu? -
1) Not only overburning, but it also depends on the quality of the VIDEO (Birate)
2) The difference between them is the birate setting:
1.0/1.1 - Is very strict
2.0 - has more possiblities, and options for better
quality
X(tended) - is very lusive (the quality can reach SVCD)
3) menus allow you to choose which track to play, or what
chapter... Well it'a a menu... -
You can check about the differences between VCD 1.0/1.1 and 2.0 here:
http://www.icdia.org/cdprosupport/encoding/pink/mpeg1_specs.htm -
I highly recomment to read the FAQs. I think, after that you can imagine what a menu is, what a MPEG encoder is and finally what a VCD is.
TMPGEnc is a MPEG encoder, not an authoring tool.
TMPGEnc creates VCD compliant MPEG files, not the VCD itself.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
New to DV, I have several questions.....
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 3rd Dec 2007, 23:10 -
SD to HD Questions
By The Sumerian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Nov 2007, 11:08 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 14:00
