I tried to use the header trick on my MPEG file. However, when I hit run it says mpg can not be created. What am I doing wrong? Baldrick can you help me?
vts. When should I change the name of the MPEG2 file? Before I encode or after?
for ex, if your file is my_svcd.mpg, set Video input = my_svcd.mpg, Audio input = my_svcd.mpg, Output = new_svcd.mpg (or whatever). If you set Output = my_svcd.mpg, you will get the message "File exists. Do you want to overwrite?" If you click ok. you get "File... cannot be created" because you are trying to write over your input file.
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 26th Mar 2009, 00:18 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 09:36
