  1. I only saw SVCD in the tools section
    Feb 2001
    Berlin, Germany
    FitCD is a very accurate calculator for (S/X)VCD.
  3. You can find all the calculators and other supportive softwares on this address:
    http://www.digital-digest.com/dvd/downloads/index.html
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    On 2001-08-20 14:47:31, Kdiddy wrote:
    trick question??..ummmm duuuh
    www.vcdhelp.com/calc
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Yes, I know about that, but it only does SVCD, DVD, and DivX.
  5. It doesn't matter if you put in SVCD it's all the same. a 74min cdr holds 740MB of MPEG1 data or 5,920,000kbits of data. 80min cdr holds 800MB or 6,400,000kbits of data.
    You can use the calculator for any x(S)VCD.
  6. it does VCD as well, its right there!...man some people I tell ya....if it was a snake it would bit ya dick off already
