I was wondering if there was a DVD authoring/burning program that will let me create a DVD from MPEG files, but instead of creating a new menu, let me use one that I already have from an IFO/BUP File.
can u explain it a lil bit better because a ifo/bup file is not the same as a menu
check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
Try the ifoedit site.
Seems to have many guides dealing with ifo, vob and mpeg.
http://mpucoder.kewlhair.com/derrow/index.htmlThere's not much to do but then I can't do much anyway. -
I guess I'll basically spell out what I want and hopefully someone will understand and have a solution. Using SmartRipper, I ripped the files from a DVD to my hard drive. Then using DVD2AVI, I separated the audio and video into the appropriate d2v and wav files. Instead of it combining the sequential files automatically, I did them individually. Then I opened them in TMPEGEnc and created DVD quality MPEGS. Then I renamed them to vob. So basically I have all the same vob files that were on the original dvd, just a smaller size. If I try and burn a DVD with nero, using the original IFO/BUP files, it doesn't work b/c obviously the specifications aren't correct. When I create IFO/BUP files with IFOEdit, and burn them to a DVD, It also doesn't work, I'm guessing b/c IFOEdit doesn't support menu's. So is there a program out there that will take my newly created VOB files and create IFO/BUP files that will work, and if menu's are the problem, then it needs to support menu's? Thanks!
wait a minute....."U renamed the mpegs u created in tmpg to .vob" doesnt work like that..sorry
i dont know where to start on this one..lol
first lets start with u ripping and using dvd2avi to get a d2v and wav for each vob.........not needed
u could use smartripper to rip the whole movie straight to a m2v file but since u ripped the vobs lets use the vobs
u should have loaded ALL the vobs into dvd2avi to get 1 d2v file and one audio stream...and i wouldnt demux the audio to a wav file because it will take up too much space always demux the ac3 file compressed audio stream if available
use tmpg or CCE(which i perfer) to transcode the video only after which u need an authoring program such as spruce up, maestro or scenarist to remux the audio and video streams together and author the video to vob format ( if u use rempeg u dont need to use an authoring program just remux with ifoedit)...then u need to use IFOUPDATE and IFOEDIT to clean up the ifo files
theres info/guides on dooms forum on exactly how to do this , what i wrote here is basically a quick explantioncheck out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
on any dvd the VTS_nn_0.VOB file is the menu file correct? How to I burn a DVD using the menu from that file?
Invalid/IFO/BUP
By for_4 in forum DVD RippingReplies: 11Last Post: 20th Apr 2012, 03:57 -
ImgBurn 2.5.0.0 changes .IFO/.BUP
By geohei in forum Authoring (DVD)Replies: 11Last Post: 27th Feb 2010, 06:31 -
Adding .IFO .BUP etc
By captainzog in forum Authoring (DVD)Replies: 14Last Post: 18th Feb 2010, 06:45 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36 -
VOB/BUP/IFO to AVI???
By chronic777 in forum DVD RippingReplies: 6Last Post: 11th Aug 2007, 12:10
