Can someone please tell me how I can know what all the TMGEnc settings do? The website and program itself, don't seem to be very well documented, regarding any of the settings. Stuff such as (but not everything I would like to know) ;
1. The noise reduction settings what they do or numbers to try for certain situations
2. GOP structure, changing this will do...
3. Quantize matrix, changing this will do...
4. When to use some of the advanced options
Also, would someone please explain why the heck SVCD is 480x480 (NTSC). When I encode to this format I get a nice ugly box?? What happened to the aspect ratio here, VCD=352x240, DVD=720x480, and Div~640x480. How do I get my SVCD to display properly on a 4:3 ratio viewing screen, like the rest of the world?
One other thing, is it common for people to have a high performace AGP card for games and other multimedia playback, and a seperate PCI card dedicated for capture. I always assumed people only had one AGP card. I have a MSI Geforce 4 Ti4400 card which I paid $350 us 6 months ago, and am wondering if this card is considered good for capturing or if maybe I should plunk down another $150 and get a dedicated PCI capture card, although I'm fearful of the instability this may add? Would someone please explain their experiences with this. OR would an external capture card be even better, although I really don't want to spend more than $200 more on video card toys...
Thanks in advance!
rhuala
Newbie, get thee to thy Newbie Guides. The TMPGEnc Explained guide goes through most of the functions, so please read it before you do anything else, okay?
Now, SVCD files. They will be just fine when you burn them, so trust TMPGEnc to encode them properly for your burn.
If your capture card gives you the quality you need, there is no need to upgrade.Hello. -
This is more than enough for most amateurs, but if you're serious (or just a quality nut) many dedicated capture cards have the benefit of hardware encoders, and the quality of the signal may be slightly better. As for external capture cards, their sole purpose in life is to digitize an analog signal, and so naturally their quality is going to tend to be the highest, but you're going to have to shell out the most as well.
My advice is to stick with the G4 and VirtualDub.
Capture card quality question
By Hackerpcs in forum Capturing and VCRReplies: 22Last Post: 18th Nov 2010, 16:41 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 09:09 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 13:49 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
