hi,
i have recently got the cinema craft encoder lite 2.64 and the cinema craft encoder sp trial edition.
i am probably missing something really stupid so please excuse me if i sound very foolish.
when i attempt to open a avi file in cce, i get the message that thefile "is not an ecl for cce trial edition.
can someone tell me what i am doing wrong.
thanks job
ps i am trying to encode to mpeg2.. thanks
When you click file/open that is where you load the saved project files ie: you have already loaded a file and made changes to the settings and want to save it and come back later.
To load an audio/video source you need to right click on the white box and select add and then find your avi file.
This is covered in the CCE manual. -
hi,
thanks for the reply, i should have checjed the manual properly in the first place.
how do i change the frame rate to a rate that cce accepts, as i get the message 20000/1000 frame rate not supported.
sorry again ifi have wasted your time... forgive me i am very new.
job -
when I get that kind of error on a capture, I run it through virtual dub and under "frame rate" in the video tab I just change it to 29.97 and re-save. CCE opens it fine after that
hi, thanks to you all very much,
i will try that either today or tomorrow.
thanks for such a prompt response to both of you.
cheers job
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 24th Aug 2010, 00:17 -
NEW VERSION: Cinema Craft Encoder SP2 1.00.01.01
By devilcoelhodog in forum Latest Video NewsReplies: 10Last Post: 18th May 2008, 12:46 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
