Anyone have a fix for the audio static that is encountered when using AIW 8500dv? Haven't tried other programs to capture but when I use the MMC 7.7 I always get static in the audio. I checked with ATI and they are aware of the problem. On their web support page they mention making some changes in the bios but it didn't work for me. Is there any programs that can take the audio static out of avi files? My system is as follows:
AMD XP 1.73 cpu
Soyo Dragon Platinum
Cmedia sound card (built in sound)
AIW 8500dv video card
2, 100gig 7200rpm hard drives.
512 memory
Thanks for any help in advance.
Hi,
I have the AIW 8500dv also.
I only notice a slight 'ticking' sound in the background when there is complete silence on the input.
How bad would you say the static is that you're experiencing? Does it actually impede over the top of other audio?
Ian.
Home built:-
1.2GHz Athlon / 384mb ram / Full tower
AIW 8500DV
60gb & 120gb HD
Pioneer DVD- Writer, CDRW drives
Turtle Beach Santa Cruz soundcard -
No, it is just backround static. But it is quite noticeable. ATI said they would fix it in there next release of MMC. Who knows when that will be?
WOW!! Sorry for the bad grammar. It should be the next release instead of there next release. Is it Friday yet!!!!
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum Capturing and VCRReplies: 1Last Post: 16th Nov 2009, 01:11 -
ati 8500dv resource problems
By jwdove in forum Capturing and VCRReplies: 1Last Post: 27th Sep 2009, 13:48 -
Setting Up Cature Card
By I STANFORD I in forum Capturing and VCRReplies: 0Last Post: 27th Jun 2008, 08:44 -
Monitor Image Shrinks When Using Radeon 8500DV Video Outputs
By TwoTonCarmine in forum Capturing and VCRReplies: 3Last Post: 27th Jan 2008, 16:03 -
Hi8 to DVD - Use Cature Card or Dvd Recorder ?
By dearsara in forum Capturing and VCRReplies: 23Last Post: 16th May 2007, 14:04
