I'm confused over the subject of progressive or interlaced. When I scan the vob in Bitrate Viewer it says it's frame=interlaced,but if I scan the vob in DVD2AVI it says frame=progressive. Which one is correct and does it matter? I've never been able to frame-serve a vob file at resolutions higher than 352x240 and get good results. At higher resolutions I either get severe stuttering and comb lines or both.
Does progressive=noninterlced? I find that if I encode in Tmpeg SVCD non-interlaced the picture looks,to my eye,sharper then when I encode interlaced.
Does a high resolution monitor,600-800 lines,display non-interlced better than interlaced?
23.976 progressive = noninterlaced
PC monitors display progressive data
Films are nativly progressive
Encoding progressive will result in an overall better picture and a better output on a PC monitor.
If you are getting "combing" you are seeing interlacing due to telecine or hybrid materal. TMPGenc has an excellent IVTC to restore the original progressive signal if the movie is encoded "hard" telecine ( ie the video signal has been altered ). THe majority of US titles are "soft" telecine that can be fixed by using DVD2AVI's force film setting.
If in doubt search for more info. -
When I say high resolution monotor I'm referring to a TV monitor not PC.
Standard TV's are interlaced and the "lines of resolution" is mostly a bogus number. Encoding a truly progressive mpg generally improves the quality only due to inreasesd consistancy between adjacent pixels in a progressive encode.
If you are talking a TV with Componient input and progressive display combined with a progressive DVD player then yes, it would make a signifigant difference. -
Most films released to theaters are progressive. ET was a theatrical release, so it originated as progressive film. If you scanned the first .VOB in BitrateViewer, then you may have scanned the studio header / FBI warning, which are usually interlaced, and BRV doesn't continually update its info.
Always - I repeat - always, scan any .VOB but the first to get the true nature of the video. Use DVD2AVI to get the correct nature of the video. If I was a betting man (and I am) I would lay 10 to 1 odds that this is a PROGRESSIVE FILM video. Any takers? -
SLK
You are corect,I scannned the first vob in Bitrate viewer. When successive vob's it says progressive. -
I am almost 100% positive that they are... however, I didn't want to get "flamed" by stating that as an "absolute" while missing that "one" exception that someone may know about.Are not all films released to theater progressive ?
How can I know if Avi is progressive or interlaced ??
By apalace in forum Newbie / General discussionsReplies: 17Last Post: 8th Feb 2012, 14:20 -
NTSC : progressive or interlaced
By mathmax in forum Authoring (DVD)Replies: 54Last Post: 2nd Feb 2012, 07:06 -
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41 -
Progressive vs Interlaced Regarding Motion
By Brent212 in forum Newbie / General discussionsReplies: 6Last Post: 15th Jul 2009, 19:26
