I'm using PicturetoTv to create a slideshow and I noticed that the images on the VCD are degraded quite a bit. I scanned the original jpegs at 150dpi ... I assume that scanning them at a higher res will allow them to look sharper when converted to vcd?
Is there an ideal res that the original images should be scanned at? Is jpg a good enough format?
Thanks for the help.
jpg is fine, when I scan an image I do so at a minimum of 300dpi.
I think PTV encodes your images into a movie so you can have transition effects so the picture degrades a bit. Try Ulead DVD PictureShow. There is no transition effect but I will take the clear pictures.
I also used this a while back.
http://www.xatshow.com/screensaver_maker/index.html
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
How to rip the video from (S)VCD CDs or BIN/CUE images
By Baldrick in forum User guidesReplies: 45Last Post: 4th Aug 2010, 05:56 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 13:23 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57
