  1. I downloaded a move clip, and I can not get the sound working in Media Player the video plays perfectly, but no sound... I loaded the file into Virtualdub to get the avi information:
    Virtual Dub File info:
    Video
    Decompressor XVID MPEG-4 Codec
    Audio Stream
    Sampling Rate: 48000hz
    channels: 2 (Stereo)
    Compression: Unknown (tag 2000)
    Preload Skew: 1200 samples (0.25)
    # frames 90019
    I have got XVID installed....any ideas?
    cheers
    Micky[/img]
  2. You are missing an audio codec. Try installing the Nimo codec pack.
  3. I have tried installing Nimo, but then my Media Player Starts crashing, and then when I uninstall nimo, windows media player is ok....
    is there anyway to find out which codec I need to install
    Micky
  4. Hmmm, I have heard that G-spot from www.doom9.org can do this, certainly for video, may work for audio. Give it a try.
  5. I installed windows media player 9....and when I try and play the file its says that the audio codec is reported as Tag 2000....but I have never heard of it...I did a search on the net and got nothing....
    this is driving me nuts...
    micky
