Thanks guys for the help that you've given me so far. I have tried to get a good video quality in vcd, using tmpgenc to encode, and easycd for the burning. The last movie i encoded i increased the birate to 4000, after the encoding finished i attempted to burn to cd. An error appeared telling me i need a mpeg encoder and a capture card. I don't see any freeware for these applications anywhere. Must i purchase either of these programs in order to get half way decent to good looking videos? I just want vcd's to play on my dvd player.
If you increase the bitrate you are making xvcd and easycd can not burn those. Try instead VCDEasy or Nero. But be sure to read our dvd player compatiblity list to see how high bitrate your dvd player supportsor if it support xvcd at all. Most players only support max 2500 kbit/s for xvcd/xscvd/svcd....
/Mats -
I second the recommendation for VCDEasy.
Also, this other site is geared toward getting the most out of VCD:
www.kvcd.net
The templates for TMPGEnc offer leaps and bounds over standard VCD. Just make sure you check to see that your player(s) is compatible w/ the templates and you'll be on your way. I use the KVCD PLUS 352x480 template for most everything. You can only tell the difference between the VCD and the source DVD during cross-fades (slight artifacts). There are forums there if you have any questions about the templates.
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13
