Is there a tool out there what will allow me to cature in real time the audio streaming for a internet radio website?
Cheers
Paul
Dont know of any tool but if you're lucky enough to have two PCs with sound cards then use the line-out or headphone jack (laptop) from one PC to line-in on the other and a suitable sound editor which records/edits WAV files. Results can be quite good.
There was a program out a while back called "StreamRipper". This app can be used to rip streaming MP3s and will even cut individual files for each song. This app is good for streaming like "Spinner" and other such online radios.
There are programs out there that can rip any audio you play through your computer. Here are a few I know of:
AudioGrabber (A++)
LoopRecorder (B)
I believe both of the above mentioned apps are Shareware but you may be able to get a Freeware app. Check out Download.com
With audio "grabbers" such as those listed above, you will need a full-duplex sound-card and make sure you have WAV Recording setup. These apps just record any and all audio playing through your sound-card. I have had great results with AudioGrabber in ripping RealAudio and streaming Windows Media Files.
Good Luck!
Internet radio player?
By AlanHK in forum Software PlayingReplies: 2Last Post: 22nd Jan 2011, 07:31 -
How to capture and burn streaming tv internet video
By robrpb in forum Video Streaming DownloadingReplies: 15Last Post: 4th Jun 2010, 02:02 -
Capture streaming video (off of a internet connection)?
By Po|arbeaR in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2008, 18:53 -
virus internet suites and video capture advice sought.
By DBenz in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2007, 21:19 -
Do you listen to streaming internet radio?
By yoda313 in forum PollsReplies: 13Last Post: 25th Jun 2007, 21:54
