Ok need some help, i have joined a movie site and have a choice of wot format i can download the movies in ie, divx, svcd, and vcd.
Wot i want to do is download a movie then compress it narrow the bitrate and audio so i can get a full svcd on 2 disks instead of 3. Wot i want to no is if i download it in svcd format and then compress it will it, will it then be xsvcd, as this is no good 2 me as my dvd player doesnt support it.
But if i download the movie in divx and compress it and then change it 2 svcd will it just be normal svcd or xsvcd.
Any tips or help would be most apreciate as its driving me nutts, cant thank any 1 anuff who helps me out!!!!!!!!!!!!!!!!
jamie
divx---->convert to svcd, then you can specify the length. ie fit on 2 discs
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
