i capture video using ATI MMC in VCD format but when i cut out the commercials the audio goes out of sync in the clips. If i re-encode the video (using tmpeg) before i try to edit it then the audio is fine, but that adds about 5 extra hours to the process that i would rather avoid. The file details (bit rate, mux rate, etc...) all seem to be the same before and after encoding so i don't know why i have audio sync errors before re-encoding but not afterwards. Any thoughts?
Results 1 to 1 of 1
Encoding errors, cannot burn DVD
By Surber in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2010, 12:55 -
How to check for encoding errors
By Dark Alpha in forum Video ConversionReplies: 5Last Post: 30th Jan 2010, 11:25 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 15:39 -
CODECS-Too Many? Find and Clean-A/V sync Errors
By mrlewp in forum Software PlayingReplies: 9Last Post: 17th Apr 2008, 06:33 -
video audio sync errors
By demonwarrior in forum Newbie / General discussionsReplies: 8Last Post: 21st Sep 2007, 07:50
