I am new to this technology and this is a very basic question but I could find no entries addressing. WHen I burn AVI/MPEG to VCD (using EZ Creator 5) and play it on DVD player (Sanyo 370) the picture quality is bad-grainy, pixellated, poor color. Is this normal? My understanding was that VCD was comparable to VHS.
The quality depends of course on the MPEG encoder, its settings, the quality of the source.
It really does depend on your source file.
If you don't like the quality of a video that you have as a file, it's not going to look much better on a VCD. If you want better-than-VHS quality VCDs, then (generally) only convert files that play smoothly and clearly on your computer. I generally stay away from avi files altogether, because the level of compression in DIVX, which most avi files are compressed with, isn't something I want for my VCDs.
Look into SVCD as well if you want good picture quality. I've had great results with the SVCD format, noticably better than VHS and, to many, comparable to DVD (although in reality it isn't, it looks the part).
<font size=-1>[ This Message was edited by: oNikke on 2001-08-20 15:01:21 ]</font> -
OK, how do I do SVCD? WHen I have loaded the template in TMPGENC, my burning program displayes error messages saying the file will not be playable in a DVD player- wrong frame rate, audio, etc.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
