OK I just got a new Maxtor 120gb hdd and I installed it and everything went fine but when It was finished I rebooted by computer and the drive said it had 34.1gb of space its supposed to be 120 isnt it?? what is wrong
Closed Thread
Results 1 to 10 of 10
*pardon my english, I dont take the time to type right.*
___insert witty, well writen, thoughtthrough comment here___
O thats probably it I had some issues with setting up the bios thing in Windows XP pro. Now this is gonna sound kinda stupid but how do you set up your bios??? I know I should know. but everybodies gata start someware right.
Go into you BIOS and try to make it recognize the drive to its full capacity. If that doesnt work, contact the maker of your machine and ask them what their ideas are, they could give you the model of BIOS you MAY have to upgrade to to make it see the full disk.
Thats the main problem with drives growing so quickly. The MOBO makers havent really caught up yet on all but the newest machines.A bird in the hand is worth a foot in the tush-Kelly Bundy
xp has a huge terabyte (way bigger than your 120giger) limit..
to enter your bios, when you computer first comes on it should say something like "press f2 to enter setup" it could be DEL, F1.. if it comes up with a splash screen, try pressing escape..
as deviemi83 said, it may be a limitation of your bios that is not showing the full capacity of the drive, but its not windows xp..
you might want to try download some of the utitilities maxtor has to offer..
if none of that works, you can always go and buy a pci controller card.. i've got one, it works great and its faster than having my harddrives hooked up than straight on to the mobo.. but you've gotta have the primary master on the mobo..
Next time you want some help, only post the topic once!!!
http://www.vcdhelp.com/forum/viewtopic.php?t=120056
Rob
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Hard drive problem
By bballnut in forum ComputerReplies: 6Last Post: 16th Dec 2007, 20:31
