  1. Hey guys...I just download austin powers 3 and that's xvid..and I'm having a little problem....there's a huge sync problem in the second part of the movie.....here I'll tell you step by step what I did.....I downloaded the movie..and it was just one file...so I went into virtual dub...and it popped up a messeage which said...something like....."Virtual dub has detected an improper VBR audio encoding in the source AVI and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce 100256 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 133.6 +_ 36.8 kbps)" IF i knew what this message ment..I'd fix the problem...but since I don't...I just pressed ok.and went on....I then went on to spliting the avi into half..by selecting direct stream copy....and after that I encoded with tmpgenc...after I converted I noticed that the second part was out of sync.......how would I go about fixing this problem......thx....
  2. Well as the message said VirtualDub can't handle the audio which is in mp3 VBR. But the NanDub which is almost the same as VirtualDub can handle VBR audio.
    You know what to do
