Cinema Craft using multipass VBR makes separate video (mpv) and audio (mpa) files. How do I put the video and audio back together to make the MPEG-2 file? Can Cinema Craft do this or do I need another program? I think I've seen that TMPEG can multiplex and de-multiplex this stuff, but the question is it seems weird to me that Cinema Craft cannot do this. I'm thinking I need a hint at how to do it in Cinema Craft.
Help would be much appreciated. Thanks in Advance.
Postul8or
Cinemacraft CAN do this - but it does a fairly poor - make that very poor job of it.
For MPEG2 it's called a Program Stream ( PS )
For MPEG1 it's called a System Stream ( SS )
I have had real problems with certain files - some play with my hollywood + others fail
just multiplex them with TMPEGenc
or BBMPEG if your really keen -
Alright I'll give this BBMPEG a try. Thanks for the advice.
It's re-assuring to know that I'm not crazy that it is not possible to get a VBR encoded MPEG in Cinema Craft to go to an .mpg file. -
Hmmm, in bbMPEG .mva files are not accepted. How the heck can I put the audio back with the video file with this tool?
Looks like I'm using TMPEG -
Just rename the audio. I think BBmpg uses mp2 for audio. so just change the mpa to mp2
Alright I was thinking of trying that so perhaps it was worth a shot.
Something i noticed when I went ahead and used TMPEG to multiplex is that it appears I made the SVCD @ 6000kbps! I could swear I told it VBR with 300 as the min, 2300 as the average and 2520 as the Max. Guess Cinema Craft will be running overnight again and hopefully doing the job @ 2300 not @ 6000kbps LOL!
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 13:30 -
MPV and MPA out of sync with Media Player Classic
By Talayero in forum Newbie / General discussionsReplies: 2Last Post: 13th Mar 2009, 08:34 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51
