whats the best, fastest and easiest software to use to join .avi files b4 chgin them to mpeg2 wit tmpgnc ????????
Results 1 to 16 of 16
ALWAYS HAD TRBL WIT THAT SOFTWARE.... DOES ANYONE ELSE HAVE A BETTER SOFTWARE?????
Panasonic DMR-ES45VS, keep those discs a burnin'
ok..... i need a software thats quick and easy to do it.... not a files.... but thanks anywayss
evening all.
mol3000,
Seriously, vdub is what you are looking for. I don't kno whta troubles you
were refering to (other than it's capturing I'll assume) don't let it fool
you.
Ok, in vudb, if you want to edit multiple segmented AVI's, you have to:
* always be sure when you are (assuming this is for captures) capturing,
.. you set your segmented files using numbers, ie, I always use 10 as my
.. starting AVI filename. Then, when you capture w/ your app ie, either
.. AVI_IO or vdub, these apps will insert numbers. So, when you named your
.. AVI file to 10, in:
*** AVI_IO, would name each file, ie, 10_0.00.avi, 10_0.01.avi, 10_0.02.avi and so on.
*** vdub, would name each file, ie, 10.00.avi, 10.01.avi, 10.02.avi and so on.
* Now, in vdub. . .
* open first avi, (ok to drag the first one)
* then, File/Append AVI Segment... and look for 10_0.01.avi (if AVI_IO)
.. or 10.01.avi (if vdub)
* then [x] Autodetect and vdub will bring in all the remaining segments.
.. this is located at the very bottom left corner. If you don't check this,
.. you'll have only Appended the second avi file. So, make sure that you do.
* once you [x] that box above, click on the [OK] button, and vdub will
.. proceed to import all those segmented AVI files. When vdub is done
.. importing those files, look down to your lower left, at the bottom of
.. vdbuds window. You should see how many AVI segments it imported.
.. for ie, if you have 3 AVI files to import, ie 10.00.avi, 10.01.avi and
.. 10.02.avi, vdub should display 2 at the bottom... meaning that it had
.. imported 2 segmented AVI files into (at the end of) your current AVI
.. file already in vdub.
* however, say you have 3 files (as above) you could save a step, and
.. just use vdub's File/Open and select your main file, starting w/ lowest
.. number, ie, 10.00.avi and again, click the [x] Autodetect box at
.. the bottom of the OPEN window, and vidub will bring in all those AVI files
.. ie, 10.00.avi, 10.01.avi, 10.02.avi, and then this time, you would see a
.. 3 at the bottom left corner of vdubs screen.
That's it. Now, you can edit the clip, ie cut out the commercials.
-vhelp -
ok.... i did that in virtdub but do i save it or what????? once i pic the second file.... what button do i hit for it to combine both .avi files together?????????
mol3000,
sorry, i left the Press the {oK} button. However, I've revised my steps
above. So, plase have a re-looksees.
-vhelp -
COPY /B avi1.avi+av2.avi+avi3.avi+avi4.avi......... newavi.avi /B
in a command window ... -
Hi Vhelp.Originally Posted by vhelp
What you describe above Doesn't work for me when I try to open files
in order to Join. -Neither Do I see anything at the bottom left corner of vdubs screen.
When Used with the Append Segmented AVI command It works fine.
This is what I tick in the Open Window...
Automatically Detect and Load additional segments
I`m not capturing , just opening with the aim of joining.-Direct Stream Copy.
Is it not applicable or meant for this?
What am I getting wrong, I`ve always wanted to ask this.
Thankyou.
____________________
Rainstar.
[/b] -
ok... i did all that and save it as another file..... so i guess it did its combin thing ( I didnt get to really look at it b4 i left ) but when i combine them the avi file came out to be 25 GB!!!!! I EVEN DID A REFRESH AND IT WAS STILL 25GB..... well what i did is b4 runnin out the door i put it thru tmpgenc for dvd hoping it will just shrink the file size to what it should be.... but i did cbr 6000 for a 2 hour movie so i hope it fit on my dvd..... BUT Y DID THE AVI FILE COME OUT TO BE 25 GB????????
and how did i do that..... and how do i un do it???????? will my mpeg come out ok???????
evening mol3000,
well, in vdub, when you want to save an combined (or marked segment) avi
from vudb's timeline, you have to:
* move selection to... Video/Direct stream copy
* then, File/Save as AVI...
and finally, the video will be saved, w/out decompressing or recompressing
any of it. This should keep your TOTAL AVI file size at the same size.
Thats it.
If you want to save an segment of any port of the AVI in vdub's timeline,
you have to:
* assuming you wanted to cut out a commercial between your segmented AVI
.. capture of Cosby Show, but it's a preview of a NEW movie, and you feel
.. like doing a test encode or maybe to share w/ friend in divX format...
.. then, in vdub, you would...
* use the /__ and __\ to select that part of the video in the
.. avi from vdub's timeline, then
* move selection back to... Video/Full processing mode
* this is optional... Video/Compressoin... and select a new codec,
.. ie, MJPEG or PIC or Huffy, divX etc.
* then, proceed to continue working on your current video project.
Thats about it.
Hope that all helped ya and others' out, too.
-vhelp. -
hi. vhelp.
Sorry about the abruptness.
I realized that the Automatic option on the Open Window is
only for segments tha Vdub has tagged I think.
Thanks,
____________
Rainstar.___________________
Rainstar.
Need a AVI to DVD software
By dvd mon in forum DVD RippingReplies: 4Last Post: 8th Mar 2011, 15:28 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Software for VRO->AVI
By Lefteris in forum Video ConversionReplies: 2Last Post: 11th May 2008, 03:35 -
AVI To DVD Software
By gomer in forum Newbie / General discussionsReplies: 2Last Post: 25th Oct 2007, 03:12 -
Avi splitting software?
By majax79 in forum EditingReplies: 14Last Post: 14th Sep 2007, 01:35
