  1. Hey guys....I just saw the the audio sync problem guide message....I was quite interested when a person replied that all dvd sync problems are man made setting mistakes.....the reason why I'm mentioning that is because I myself have had many dvd out of sync problems...I was just thinking that u guys may be able to help me fix them...the problem occures after I split up the avi dvd file into 2 files then convert those files into mpgs using tmpgenc.the audio sync problem only occurs in the second part of the movie..not the first part.....so basically this is the process that I go through when converting my .avi dvd rips to mpg so taht I can watch them on my dvd player...First I go to virtual dub..and I split the single large avi file into two parts...so taht it will fit on cd's...I do this by selecting direct stream copy on the video tab......then after the files are split into two..I extract the wav. audio from both of the files using virtual dub......after that is done..I go to tmpenc and convert both of the fiels into mpgs...after this process has been completed and I go to check what my finished product looks like...I"m quite shocked to c that the second part of the movie audio is out of sync..it starts off fine but then just trails off....any help would be appreciated....thx....
  2. help would be appreciated
