  1. after i encode a .avi file in tmpgenc i can't view them in windows media player, divx player, or winamp! What am i doing wrong (is there a codec i have to d/l if so which one)?
  2. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Did you encode it as an mpeg2.
    If so look on the left panel Other...Tools...Codec and Mpeg2 there is a free codec needed to view mpeg2 with the windows media player.
    There's not much to do but then I can't do much anyway.
  3. Left panel of what??? because if u are talking windows media player i see nothing.
  4. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    This forum
  5. well i d/l the codec for mpeg 2 and now when i open it up with windows media player (9) it comes up with an error saying it needs some codec but then when i go to the site they tell me it says it is unavailable. help
  6. also by mpeg 2 is it supposed to come out as a .mpg file?
  7. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Just because you posted in the newbie conversion doesn't mean you are a complete newbie so its difficult for me to know your level of expertise.
    My first question to you was..... is it an mpeg2? I then said: If so look....
    Since you encoded it you must know if you intended to create a vcd (mpeg1) or svcd (mpeg2). The reason I asked that is because if it was an mpeg2 perhaps you were missing an mpeg2 codec. That's a common problem.
    You never answered the first question.
    Is it an mpeg2?
    By the way...
    I don't know if you know this but , you can also view mpeg with a software DVD player.
    I could ask other questions but lets deal with this first.
  8. sry my bad...it was a mpeg 2 and i d/l a dvd software player and it works fine...thankyou for the help
