Hi
The problem is when i'm capturing video with virtualdub, i get no audio only the image
(capturing with divx 4 low motion). i play the outgoing video but there's no audio. what i'm doing wrong???
Today is the last day of the rest of your life
Sometimes the cap is ok but the wave audio is muted so check the play settings.
Also make sure your line in 'record' is clicked on.
Can you play other audio, can you hear the audio while you record?There's not much to do but then I can't do much anyway. -
yes i can hear the audio, but i found the solution, this card have an audio line in, but i cannot capture the audio that way, i only can capture the audio through my creative awae, but the sound is creepy, thanks a lot for helping me...
A working XP SP3 driver for Flyvideo 98 - Please help
By danroberto in forum Capturing and VCRReplies: 5Last Post: 28th Aug 2010, 14:10 -
how to use audio interleaving in virtualdub?
By sharmine in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2007, 03:00 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 22:51 -
VirtualDub + New Audio + Editing + Audio Intact?
By hech54 in forum EditingReplies: 6Last Post: 16th Aug 2007, 15:57 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:12
