  1. i recoreded some mpeg2 file from my tv tunner capture card. some file are pretty big. i want to cut out some of the commercials and stuffs like that but the file ended up around 400mb for a 20-25 mins show. i look at some of the mpeg file that dvd2svcd make from ripping dvd. i notice the file is about 750mb and the running time is ~ 60 mins. i just wonder what program should i use to make my file smaller and have good quality. thanks.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    tmpgenc or cce or mainconcept will work to re-encode ... cce you need a few more steps
    tmpgenc you can edit with ..
    or edit with bbmepg but a bit more work ..
    or vegas video can do all edit and re-encode in one shot ...
  3. Originally Posted by BJ_M
    vegas video? i have sonic foundry audio 2, the prog have the video editing too. this is wat i used to edit the mpeg2 files. how does the re-encode work. how do i do that with tmpgenc? and what's the setting? is there a guilde for that? thanks.
