Hi,
Could someone please name a capture software that can record at 480x480? this is for making SCVD. I have Cyberlink Power VCR2, Ulead DVD Factory, and Virtual Dub (which wont read my capture card).
Thanks, your help is appreciated![]()
Powervcr2
There's not much to do but then I can't do much anyway. -
But You will have to tweak the registry to capture at that res.
The virtualdub issue is caused by the drivers. Vdub needs vfw and you have wdm thats normal.There's not much to do but then I can't do much anyway. -
I found these registry entries myself.
If you read my previous posts or search the forum for powervcr you will find at least 2 recent places where I give a basic explanation of what to look for. There are some older links too.
I won't say more than that because its very straight forward. Anyone who needs more help should not play with the registry.
I am not being mean but if you get in trouble I will not be able to help you cause when you mess up the registry your system will cause you problems.
If you are experienced it will be easy for you.There's not much to do but then I can't do much anyway.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
