Alright i have used virtual dub to convert the audio in a divx movie i want to burn. I am using TMPGenc and was wondering if i should use that to put the video and audio together or should i just encode the movie with that program and use something else to put it togher...which program do u suggest to put them togheter?
I guess the easiest way is to encode the avi file and the wav file in TMPGenc at the same time. TMPGenc will automaticly multiplex into one mpeg II file
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 10:06
