I converted the sound with goldwave
and coded the avi in tmpgenc to vcd
but the audio is out of synch....
virtualdub could not code the sound from the movie at all...
(the requested audio compression is not compatible with the input format
check thart the sample rate and channel count of the input match those
of the requested format)
ive got nimo installed.....
please help.....![]()
Were you doing a Full Processing save the wav as uncompressed?
I've never had a problem that way.... -
Sounds to me that this file has an ac3 5 channel audio stream. Check file information to be sure. If so follow this guide.
http://www.vcdhelp.com/forum/userguides/91588.php -
I LOVE YOU MAN
turned out real nice with that guide....
thanks alot craig... -
Glad to help
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 07:27 -
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 21:59 -
Audio synch problems after muxing.
By avengerevenge in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2011, 19:27 -
WinAVI 9.0 Audio synch problems
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 12:10 -
By zinc in forum AudioReplies: 4Last Post: 6th Jul 2007, 22:22
