How to edit/replace a sound layer of a VCD?
Because sometimes, there're VCDs that have 2 sound layers. Example, karaoke VCDs
You can use vcdimager tools vcdxrip I believe to get the files. Check the normal left & right audio tracks - if they are significantly different pick the one you want & copy to the other track. Reassemble, reauthor, & burn. Not step by step but that is the gist of it.
Panasonic DMR-ES45VS, keep those discs a burnin' -
thx
btw, u said VCDImager right? do u mean VCDImager GUI? coz if it's VCDImager GUI, there's almost nothing in it, can't play with sound
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
