hello , i can capture good quality dvix video with virtual dub but....everytime i have to set all the parameters again....can i save these in a way so i dont have to set everything again ?
thx 4 reply
guy belgium
You mean by selecting Capture-->Preferences-->Save current settings as default?
[img]http://photo.msn.s8.com/MS8zLzEwMzU0OTg0NDkvMS80MDE3LzE1NS8zMi96WjlFRlpXY1 lOemN6cjcyMk40SFpR/b240fac8583aa9a829743f345d8c5522/clbk=HcZNnT9kkUiOsWHzmunMZ0u8SMH8kSNK*ur477qvC3GQg HDzRzIyFv*c0IEaNEVjSj2lRXB*B70$/jpg.jpg[/img]Hello. -
I have a similar problem when I capture files using VDub.
In "Capture" mode:
I goto Video, select a codec, and set accordingly.
I goto Audio, select a codec, and set accordingly as well.
I may also (depending on the file) utilize one or several filters that are
found under "Video --> Filters".
Also, if I choose to crop the intended capture 'on the fly' I must enable cropping (under the Video? menu).
Now, I can go and select the Cap -->Pref-->Save current and all appears to be well.
Unfortunately, none of these settings is saved when the program exits.
The only thing that I have found that will actually save under Vdub (1.4.10) are the "Load Processing Settings" under the file menu while in Edit mode. This will allow you to reload previously defined sets of filters, and possibly custom a/v codecs.
I use Win2k, and have no other errors when I use VDub. Just that these settings are all "forgotten" each time VDub is closed. Closed here means the program as a whole, not exiting out "closing" out of Capture mode.
Oddly enough, some settings remain after exiting from Capture mode to Edit mode (cropping for instance), but a/v codecs will not.
If there is some bonehead thing that I have done (or haven't done) to fix this plz let me know. -
well Darkelf...i have the same problem , it's does not save...
is there no other program to capture directly to DVIX but that is more 'user friendly' ? ( like a standard video recorder )
Guy
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 21:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Avidemux - Save settings?
By Shadarr in forum EditingReplies: 2Last Post: 15th Jun 2009, 10:19 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36
