I have a VCD rip in cue/bin format which doesn't burn correctly using Cdrwin or Nero.
I mounted the bin with winISO, inside there are 5 folders :
CDI
EXT
MPEGAV
SEGMENT
VCD
Any ideas on how to convert the files inside the folders to a playable mpeg file ??
Cheers,
F.D.
http://www.vcdhelp.com/convertdat.htm
The dat file inside the MPEGAV directory is playable already. Use windows media player or a software dvd player.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
Need mpeg-1 to VCD tool that splits
By anadiner in forum Authoring (VCD/SVCD)Replies: 14Last Post: 4th Dec 2009, 05:24 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
