I posted a message through yesterday about different avi formats, and got a reply to use the nimo codec pack, its working fine and would like to thank tommyknocker for the info, the only thing is, since I installed it my monitor keeps on flickering on and off, I dont know if this is to do with nimo or what, can somebody please help, Thanx.................![]()
Could be a conflict with your video card drivers or the wrong refresh rate.
There is a warning during the installation about one of the drivers in the package. I have also found that some of the other drivers not mentionned by them also caused conflicts or replaced working divers with non-working versions. I had to deselect a number of drivers otherwise my Intervideo apps no longer worked. I kept getting illegal instructions after installing the full package (-1).
My suggestion is to uninstall the pack and just install what you feel you absolutely need.
I had to do it by trial and error so don't remember which drivers I reselected in the end.There's not much to do but then I can't do much anyway. -
If you installed 50 Build 8 then that is your problem - this version has some instability issues in addition to being bundled with spyware. Install 50 Build 7 or Nimo Lite Pack.
HD - DVD = Movie flicker or something
By Electric Blue in forum Video ConversionReplies: 25Last Post: 18th Jun 2011, 13:43 -
Computer Monitor Flicker Problem
By Xenon77 in forum ComputerReplies: 2Last Post: 7th Sep 2009, 17:15 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
That flicker again on my DVD-R transfers!
By ministry88 in forum RestorationReplies: 11Last Post: 13th Apr 2009, 15:34 -
Flicker effect
By wan2no in forum EditingReplies: 1Last Post: 26th Jul 2007, 21:38
