Hi,
I am using dvd2svcd. I want to only rip selected chapters out from a DVD. How do I go about doing this using this program?
If it is not possible to do this with dvd2svcd, what else can and how I use to accomplish this.
Thanks.
on the conversion TAB there is the length of the movie
when you click that you have the option of
selecting the chapters you want
also on the CD IMAGE tab the bottom
right hand side has either custom chapters or
DVD chapters
I found these just recently after aroung 5 discs with 40 chapters plus
trial and error
it is a great program
Villafan
Movieconvertor Studio (V1.6) Hangs but works when selected ....
By phase52001 in forum MacReplies: 4Last Post: 8th May 2012, 22:25 -
How do you blur selected frames in AVIsynth?
By Nagashi in forum EditingReplies: 4Last Post: 9th Jan 2011, 20:30 -
Selected input is not BD format
By Mark AL in forum Authoring (Blu-ray)Replies: 8Last Post: 5th Oct 2010, 03:30 -
RipBot264 Question Regarding Demuxing Selected Streams;
By vrblkent in forum Blu-ray RippingReplies: 7Last Post: 29th Dec 2008, 19:25 -
How to place selected subtitle(s) at different locations from the rest?
By qknet in forum SubtitleReplies: 2Last Post: 8th Oct 2008, 02:09
