i downloaded some movies and i can't get them to play. i downloaded nimo codec pack and they still won't play. some avi files play and others don't . can somebody help
....and are you sure those files that don't play are AVIs. If yes, did you select ALL codecs to be installed when you installed Nimo Codec Pack?
How do we know which Codec is needed for each AVI files ?
AVI codec are so fragmented, such a pain !
I need to load many to play the stuff off camera capture, web, and other... -
You can check which codec you need in AVIs properties - it should tell you which one was used to encode it. If not, open the AVI in Virtual Dub and go File->File Information - it should tell you here too.
i got the files from users on kazaa. and most of the files i can view its just some i cant. i tried viewing with divx player and windows media but i just get a blank screen
What software do you use to play your computer media files?
By johns0 in forum PollsReplies: 20Last Post: 22nd Feb 2012, 05:39 -
MPG files play fine on computer, no audio on DVD player
By kenimpzoom in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2010, 15:07 -
Can one play computer files on DVD machine?
By kevs in forum MacReplies: 12Last Post: 6th Jan 2010, 13:00 -
Can't Play EVO files on my Computer
By wulf109 in forum Software PlayingReplies: 2Last Post: 10th Mar 2009, 09:12 -
Can you play HD Divx files only on computer?
By chin569 in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2007, 12:19
