Used Primo to back up Hotshots GOlf3. The DVD game is a tad below 2gig. I went to full application and did the build the global image thing. Then i burnt it to a Memorex dvd-r. When i went to boot the copied game in my PS2 it went to the PS2 logo screen but then goes to the memory card screen. I also tried Stomp and did a disc copy method which resulted in the same result as the first one. Im using the Pioneer 104 with the px engine and 1.32 firmware upgrades. Is it the media that is causing the problem? I didnt get any errors when reading and recording.
i assume you have a modchip installed in your PS2 ?. otherwise you won't be able to boot it.
Have a look at www.ps2ownz.com as they have loads of guides on backing up PS2 games. -
Yes i got a magic2. My PS2 will play all except a DVD movie and a DVD-R backup. It will play a DVD-rom game. So not sure if its the media. Im gonna try a different brand to see.
i've found my PS2 only loads certain brands of DVD-R's but others play them fine,
i have an xbox and ps2. i would like to make copies of games but i was wondering how reliable are these chips
WooooHooooo! I got my REAL(f**k them clones) red Magic 2 installed today!
I love this dayum chip, it plays everything!!
Anyways, i just did a back up of Tekken 4 using RecordNow MAX and mine came out working great. I always use Apple DVD-R's.
Okay, i assume that the game you're backing up is a DVD-Rom and not a CD-Rom? Well either way, put the game into your DVD-Rom/DVD-Burner and open RecordNow MAX. Leave all the settings at default, and don't use the wizard. Go to where it says build global image and choose where you're going to save the GI file on your hard drive. Now let the drive read the game at your drives lowest speed(1x?) This is just for your benefit.
It will take longer but the odds of you making coasters in the end will be less. After it's done, then put your DVD-R in and burn the GI file you just saved to your hard drive.(preferably at 1x also)
Anyways, yea, it's as simple as that!
is record now max the only program you can back up games with? also will it work with any dvd writing drive cause im gonna buy the new Sony DRU500A. can you burn xbox games also??
*pardon my english, I dont take the time to type right.*
___insert witty, well writen, thoughtthrough comment here___
not having any luck creating my tutorials
By Dire in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2012, 22:12 -
Anybody have any luck hacking TV/DVD combos?
By Martineaux in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th Mar 2012, 11:54 -
Ripping Audio from PS2 Game Bully?
By coondog1234 in forum AudioReplies: 2Last Post: 10th Mar 2010, 09:47 -
how to backup pc game
By buck696969 in forum ComputerReplies: 14Last Post: 12th Jan 2010, 13:21 -
Tried every flv to mpg convertor program, no luck.
By ry94080 in forum Video ConversionReplies: 4Last Post: 16th Jun 2007, 00:01
