Hi if you can help me out it would most apreciate as this is driving me nutts.
Is it at all possible to get a full 90 min movie in svcd format on 2 cd,s?????? i can do it in vcd but that format ir realy bad qaulity and i want svcd.
Can you tell me in the easiest detail possible and menchen the software i will need to do this, wot is lowering the bit rate ?????
thanks a lot 2 any 1 who helps me out i cant thank you anuff jamie
It's more than possible to fit 90 mins movie in 2 CDs with SVCD format.
First of all, if you havent read this, pls read before "http://www.vcdhelp.com/xvcd.htm"
A lot of encoder software will do like TMPGEnc, DVD2SVCD, CCE etc.. If this your first attempt for SVCD you might have to install dvd player software such as PowerDVD, Windvd in order to get mpeg-2 code or you can install only mpeg-2 code (find from tool section). You need this code in order to edit, view or load mpeg2 (SVCD) file in your computer.
How? it's simple as you already know, just lower some bitrate either video or audio. At default supervideoCD template(480x480/576 @ CBR 2520kbits, audio 44.1 KHz @224kbit) in TMPGEnc you can fit only 40 mins into 1 CD, then you have to load "unlock template". Now you can change all setting in TMPGEnc. I'd suggest you go with 2-passVBR @ avg 2200, max 2520, min300 or CQ @ max 2300 min 0. You might as well consider for CVD (res 352x480/576). -
thanks 4 advice mate,!!!!!! i am trying to open a svcd movie using tmpg and it says unserported how come is this?????
i have the mpg2 codec installed as i am able to watch svcd on my computer can you think of wot the problem may be ???? -
You might use an old version which in not support for directly encode mpeg2. The other way around is to use dvd2avi to save project of that mpeg2 file. Then open "d2v" file instead of mpeg2.
Help reset my expectations - how big the rip will be, time it takes to..
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2009, 14:10 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 15:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 23:08
