Hello all,
This my first post, I hope you can bear with me. I have just converted an avi file to mpeg1 using tempg. Later I burned onto 2 cds. The video was ok the only problem I had was, about 40min into the movie frames started droping out like crazy and the sound was poping. This happend for about 3min, then it was ok again, Also the picture was blocky in dark seens. My question is, how can I create the best quality vcd video wise, and also have it fit full screen. I have a 32inch tv and wide screen is to small. Also could someone explain the aspect ratio thing 1:1 so on???????
Thanks in advance..
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 19:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 02:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 14:13 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
