When converting from my AVI 320x240 to VCD 352x240 my video quality goes from good to poor. What I want to know is, is there a way to make my quality stay the same. I am using TMPGEnc. Someone told me it should be 640x480 for good quality but i cant get my AVI any higher resolution without losing Quality. Please Help
StormStrickland
What if you use VirtualDub's resize filter and frame serve to TMPGEnc? I've no idea if it helps in your case, but worth a try. With a decent processor, it will have little if any impact on your encoding time.
/Mats -
...and remember - There's NO way to make the "quality stay the same" since MPEG is a lossy encoding method. You can ether go for SVCD (MPEG2) or XVCD by raising resolution and bitrate to achieve best possible results.
/Mats
Issues converting to 320x240 AVI
By 009 in forum Video ConversionReplies: 5Last Post: 14th Jul 2008, 03:23 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
320x240 avi's to Half-D1 Resolution
By louv68 in forum Video ConversionReplies: 10Last Post: 15th Aug 2007, 09:12 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
