I have only been doing this stuff for about two weeks and have converted a number of DivX avi films to SVCD using TMPGEnc with no problems.
However I have a DivX of Training Day where the source avi aspect ratio appears squashed. I want to convert this to an SVCD to watch on my (non widescreen) TV, but the MPEG always turns out squashed also.
The source avi is 576x304 at 29.97 fps.
Any step by step help on how to do this would be appreciated.
oook, here's wut u do
disable that stupid wizzard from TMPG
you open your AVI file(with the uncompressed audio of cuz)
ook, now click on LOAD (but to load an AVI file, but just, next to SETTINGs)
You open wut you want, i suggest you get SVCD NTSC(29.976fps)
OPEN
you click on SETTINGS
now, there are few things you can change now, but you need to change the Motion Search Presission: HIGHEST QUALITY VERY SLOW
and
RATE CONTROL MODE select CONSTANT QUALITY
now, ask the settings of that
and change to number to 100
next tab: ADVANCED
mark GOIST REDUCTION
NOISE REDUCTION
Sharpen EDGE
SOURCE ASPECT RATIO : 4:3 525 NTSC 704X480
VIDEO ARRANGE METHOD = FULL SCREEN KEEP ASPECT RATIO
don't touch the rest, that'll be ok
so, that should do the trick
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Thanks for your help
I had to use a source aspect ratio of 16:9 525 NTSC but the finished video looks much better.
Squashed ffmpegx Flash Video in iWeb
By IrishP in forum ffmpegX general discussionReplies: 10Last Post: 20th Jun 2011, 09:32 -
SONY DVP-SR700H - squashed DivX picture
By jhrebacka in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2010, 11:21 -
DV looks normal on camera screen, but is squashed to 16:1 when loaded to PC
By marbetu in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2010, 08:09 -
Converting 16:9 DV-AVI to Divx/XVid, its always horizontally squashed...
By mjvgiese in forum Video ConversionReplies: 2Last Post: 20th Jan 2010, 22:18 -
Streaming Video with vista 64bit Squashed! HELP!!!!!!!!!!!!
By dking in forum Video Streaming DownloadingReplies: 1Last Post: 21st Jul 2009, 14:17
