i have a couple of vcd's and i'm thinking should i convert them to SVCD.
This because the vcd's leave much space behind on a cd and if i convert them then i have a complete full SVCD.
But i know when you enlarge picture then extrpolation won't do much good, and what about the min. bitrate. The bit rate of SVCD is higher but that will not say that it will be beter
is there an advice
Assuming you are using the VCD video as the source, then going to SVCD would just be a waste of time. Video quality can only be as good as the source it comes from.Originally Posted by marcodark
-d -
The only good reasons I can think of for VCD->SVCD are:
1. You have a player that likes SVCDs better than VCDs.
2. You have the tools to create SVCD subtitles and want to add them.
3. Your VCD has two audio tracks by using the left and right channels for different languages, and you would rather have dual-audio SVCD.
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
usefull dvd authoring tools for linux
By savignien in forum LinuxReplies: 1Last Post: 12th Jun 2007, 04:21
