When I'm coding in DVD (MPEG-2) format I can choose in TMPGEnc and CCE under Quantize Matrix tab Standard Matrix or MPEG Standard Matrix. My DVD plays whatever I choose and I don't see the difference in quality of picture.
Is there any difference in quality of picture (blockiness, etc.) between these two settings?
Thanks...
The Matrix will only have a noticable effect under very low bit rates and high video motion. Even then, it might be hard to see unless you know what to look for. The matrix settings changes the compression, however it is often subjective and dependent on the type of video.
If I remember the guieds correctly, they suggest you use the MPEG setting for DVD video.
Anyone?Impossible to see the future is. The Dark Side clouds everything...
Matrix Character SubRip
By Anonymous171 in forum SubtitleReplies: 0Last Post: 7th Apr 2012, 19:38 -
Matrix DL DVD+R, Any Good?
By Des in forum MediaReplies: 12Last Post: 23rd Feb 2010, 14:21 -
What if the Matrix ran on Windows
By freebird73717 in forum Off topicReplies: 3Last Post: 12th Nov 2008, 19:29 -
matrix video clip
By theewizard in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2008, 00:22 -
view quantize matrix?
By J. Baker in forum Newbie / General discussionsReplies: 0Last Post: 3rd Sep 2007, 20:07
