Results 1 to 9 of 9
  1. I can capture and display PAL VCD and it looks fine, a size of 352 x 288 pixels which seems to be the right aspect ratio.
    When I do the same for SVCD it has a size of 480 x 576 pixels and the video is too narrow for the height ie the picture is squashed even though I have Preserve aspect ratio on. I have tried with a few different programs, Ulead Video Sudio etc and they all do the same thing.
    Why is SVCD a different size and how can I make the picture look right again?
    Thanks,
    Pat
  2. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Have you actually played this on a standalone player or just on your PC.
    There's not much to do but then I can't do much anyway.
  3. I have only played it back on my PC, is that the problem?
    Pat
  4. Yes.
    For S/VCDs, the aspect ratio is independent of the pixel resolution.
    So regardless of the fact that neither 352x240/288 or 480x480/576 in square pixels is 4:3, on a TV with a stand-alone player, it will be displayed in a 4:3 aspect ratio.
    To display your S/VCDs properly, you will need to use a player that understands aspect ratios -- i.e., I strongly suggest that you watch your VCDs with a software DVD player rather than WMP.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    or play them on your pc with windvd or powerdvd or cineplayer as these will display them correctly ..
  6. Ok, thank you both, will give that a try.
    Pat
  7. Can I ask one more "dumb" question?
    If I want to save the video file as SVCD, (I am converting home movies from videotape) should I save in the same resolution as SVCD ie 480x576 or doesnt ti matter?
    Thanks,
    Pat
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    save as what ?
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You can't save a file as (S)VCD, as this involves how files and folders are layed out on the CD. But you can save as a MPEG file, that can be used for producing a (S)VCD.
    In the latter SVCD case, 480 x 576 is the PAL resolution for the video (see WHAT IS top left).
    /Mats
