Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Hi, I want to export a movie from adobe premeire or where ever to my digital 8 camcorder. Can I do this if the movie is a divx or mpeg 4 codec? or does it have to be converted? also what software do I need to be able to do this?
    Thanks a million
    MOngoo
    P.s. I have a 2 fire wire ports on my computer, but I do not have a fire wire card, does this matter?
    Dec 2000
    Some airport, somewhere..
    Yes, but it depends on your "ports". i.e. whether they allow output as well as input. Try it. You'll find out fast enough if it works or not.
  3. The resolution will probably have to be 720x480, that's the DV codec standard (for NTSC anyway).
