I have been using smartripper/dvd2avi/tmpgenc... but thought I would give DVD2SVCD a try after all the positive comments. I am ripping karaoke dvd but DVD2SVCD is cutting the resulting mpeg into 2 parts presumably to fit onto 2 cd's. How do I stop it from cutting since I want to do the cutting myself? That is I want to chop it up into one mpeg per song so I can pick out the song I want. If it is not possible, is there a way to join back the 2 parts?
if you select save all files it will save the mpeg before cutting it (and everything else) ..
if you select do not make disk images it will not cut at all i think -
Just change the amount of CD and the CD size in one tab i donīt know the name I am at work at the moment
Change it to the needed amountīs
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
Stop Motion help?
By leth in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2010, 01:12 -
Is there anyway to stop over scan?
By andre477 in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 14:20 -
Cannot stop recording!
By paulhodson in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Jan 2008, 12:41 -
How do I make a CD-R stop playing when it's done?
By happydog500 in forum AudioReplies: 6Last Post: 9th Sep 2007, 22:12
