  1. I am new to this stuff and am trying to burn my first vcd ...
    I have captured the movie from my camcorder and saved on the hard disk as a mpeg movie file which can be played on real player...
    Can someone please tell me how to burn a vcd with this ?????
    Apr 2002
    The State of Frustration
    If you are new to this, you should read the Newbie Guides. They have the answer to this query among others you probably have.
    Hello.
  3. Banned
    Oct 2002
    southport
    use nero burn, 2 burn things on 2 cd,s mate you can download it from nero.com.
    use the nero exspress which you will get with it and it will automaticaly turn any movie in 2 vcd format.
    remeber vcd is not good qaulity i would recomend svcd it is as close as you can get from dvd.
    you can get the mpg2 plug in from kazza,com and this will all so let you automaticly burn any movie in svcd
    jamie
