I tried in the past to work with subtitles tutorials,but I never got any results,,does anybody know a simple and also easy subtitles tutorials..
I know that dvdx is the best choice,but in that case dvdx don't teach how to do it is just click and you are done,I want to understand how works and go step by srep.
thanks in advanced.
Rigo.F
Sometimes it's not worthwhile reinventing the wheel...
Have a read of the subtitling guides at http://www.doom9.org
There are two general ways of putting in subtitles from a DVD rip:
1. FlaskMPEG
2. frameserving through VirtualDub + vobsub plugin
Most people would recommend (2) but I personally think (1) is a better option (for standard VCDs at least).
If you use FlaskMPEG, be sure to get the "subtitled fixed" version of v0.6.
Regards.Michael Tam
w: Morsels of Evidence
New myDVDEdit tutorial
By myDVDEdit in forum MacReplies: 1Last Post: 17th Apr 2009, 21:14 -
avisynth tutorial
By pitaridis in forum EditingReplies: 1Last Post: 2nd Feb 2009, 07:46 -
How to create good-quality subtitles with GUI for dvdauthor?
By fvisagie in forum SubtitleReplies: 29Last Post: 4th Jun 2008, 07:32 -
EAC tutorial
By kippard in forum AudioReplies: 4Last Post: 25th May 2008, 04:06 -
Camcorder Tutorial??
By Ray & Paula in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 13:42
