  1. Hi,
    I'm using DVD2SVCD and CCE to convert some DivX .avi's into SVCD complient Mpegs. Anyway I'm not very techincally knowledgable with this stuff which is why I use DVD2SVCD in Avi2SVCD mode to do the job. It usually works ok, however I've encountered a couple of DivX avi's which cause an error in CCE when encoding (the Avi's encoded in the same way as others which do work!).
    I've tried simply clearing everything and starting again but the same thing happens at the same point, and I was wondering if anybody could help me sort it out? Here's the error I get...
    It just seems random as to which files convert ok and which don't
    Thanks...
  2. You could head over to the Doom9 forums and look at the DVD2SVCD topics. You can post your AVI2SVCD project file in there and AVS and so on and they can help you out real easily.
    You might be able to find out your problem from reading other people's posts and doing searches.
