When I capture stuff the resulting movie has an annoying flickering at the very bottom (last few lines). Anyway to prevent or remove this.
System:
AMD 1700+, 512MB RAM
Geforce 4 Ti4400
Windows XP
rhuala
We clip (or crop) them off. If using Virtual Dub, the filter is called Null Trasform. When you add it, select the Crop button. If using TMPGEnc, use Setting, Advanced tab, and double click Clip Frame option.
Hello. -
Hey thanks TommyKnocker,
One problem I am having with Virtualdub is that when it saves the video capture the capture plays back with a completely green image? You have any idea why it does that. I can view the capture fine, and when it is saving I can see the data updating on the the right (size, frames ..etc). But when I actually play back the image its all green. BTW, I'm on winXP.
Also, when you do the crop, do you crop it while its capturing or do you have to edit it after the fact. Thanks again!
rhuala -
Are your Nimo Codecs installed? (See Tools) As for when you crop/clip, it is a personal preference. If you drop ANY frames during capture. Clip afterwards. If you have no problems during capture it is okay. As for me, I clip in TMPGEnc, as part of my "tweaking" my video and formatiing it before being viewed by my friends.
Hello.
Jittery Flickering!
By Soixante in forum ComputerReplies: 4Last Post: 27th Sep 2010, 06:11 -
Menu flickering
By mrcoolekin in forum Authoring (DVD)Replies: 7Last Post: 14th Mar 2009, 12:01 -
flickering subtitles
By Pii in forum SubtitleReplies: 0Last Post: 5th Nov 2008, 05:03 -
Flickering
By artistguy68 in forum ffmpegX general discussionReplies: 0Last Post: 10th Mar 2008, 21:01 -
Flickering of DVD
By markannab in forum Authoring (DVD)Replies: 2Last Post: 30th May 2007, 18:01
