  1. Is it just me, or does the Bitrate Calculator on the XVCD part of this site not work / load up?
    As I am new and now trying to take the step from VCD to XVCD (as I understand it will fit onto one CDR) can anyone provide me with a Calculator or is it simple to work out??
    Macca
    http://www.vcdhelp.com/calc.htm
    Whats the problem with that one? just select XVCD and the video minutes, how many 74 or 80 min CDs and you will see the bitrate.
  3. The web page loads up but not the calculator, it's just like when a web page has a picture but it does not load "if that makes sense".
    Also, does this calculator do PAL?
    Is there anyway you could send it to me via e-mail.
    Macca
  4. A) Try turning your ActiveX controls in your web browser, turn them to accept unknown or uassigned ActiveX or something like that
    B) bitrate is bitrate...framerate has no affect on bitrate.
  5. Sorry, how do I do that. I had a look in Tools/internet options/advanced but could not seem to find anything say Active X?
    Macca
  6. tools-internet options-security-custom level
    or here you can lower your level if you dont feel lke doing custom
  7. Ok, found it and did both changed ActiveX and also the control level and still does not upload the bitrate calculator.
    Should I give up??
    Macca
  8. Macca, I can email you a standalone XVCD Calc program... email me if interested. davidvantrease@adelphia.net
